Automation plugins have become game-changers in the digital world, enabling individuals and businesses to optimize their workflow and save time. With advancements in artificial intelligence, machine learning, and cloud technologies, these tools are evolving rapidly. If you're looking to take your productivity to the next level, here's a look at some of the latest automation plugins on HCL Automation Hub that are making waves. Let's dive into how the following new automation integrators will enhance your HCL Workload Automation platform.
IBM WatsonX Plug-in
​Let us begin with understanding the IBM WatsonX plugin and how it benefits our HCL Workload Automation users. The IBM WatsonX plug-in enables users to receive a model-generated message from the IBM WatsonX assistant by submitting a message using IBM WatsonX’s chat completion capability.
​The plugin allows users to submit a job to receive a model-generated message from the IBM WatsonX assistant directly from the DWC. Download the IBM WatsonX plugin from Automation Hub to take your HCL Workload Automation setup to the next level.
For more information on IBM WatsonX plugin integration go to YouTube videos:
For more information on IBM WatsonX plugin go to blog link:
Google Cloud Workflows Plug-in
To enhance operational efficiency and streamline processes, one powerful tool that has emerged: Google Cloud Workflows. By integrating HCL Workload Automation with Google Cloud Workflows, organizations can achieve seamless operations, reduce manual intervention, and ensure that complex processes run smoothly.
The Google Cloud Workflows plugin is available for download from Automation Hub to boost your HCL Workload Automation experience.
For more information on Google Cloud Workflows plugin integration go to YouTube videos:
For more information on Google Cloud Workflows plugin go to blog link:
Azure Service Bus Plug-in
Azure Service Bus shines in numerous enterprise eventualities where reliable, asynchronous conversation among packages and services is important.
The Azure Service Bus can be downloaded from Automation Hub.
For more information on Azure Service Bus plugin integration go to YouTube videos:
For more information on Azure Service Bus plugin go to blog link:
Azure Batch Plug-in
Azure Batch is a cloud-based service which allows you to run compute-intensive, high-performance, high-throughput tasks without managing infrastructure. We recommend using Azure Batch to run large-scale parallel and high-performance computing (HPC) batch jobs efficiently in Azure.
Automation Hub has the Azure Batch plugin  available for download to partner with your Workload Automation setup.
For more information on Azure Batch plugin integration go to YouTube videos:
For more information on Azure Batch plugin go to blog link:
Conclusion
By leveraging these tools, users can save time, reduce errors, and focus on higher-value tasks. Whether you're a developer, entrepreneur, or part of a large enterprise, there’s an automation plugin designed to meet your needs and streamline your workflows. So, what are you waiting for? Start automating today and revolutionize your work life!
The Universal Adapter: Driving the Model Context Protocol (MCP) Client with Workload Automation
  |  September 7, 2026
Learn how HCL Workload Automation Model Context Protocol (MCP) Client acts as a universal adapter to connect MCP servers, tools, and enterprise workflows.
Modernise Legacy Ops: Orchestrate IBM i (AS/400) Green-Screen and Batch Workloads with Workload Automation
  |  September 7, 2026
Learn how HCL Workload Automation automates IBM i (AS/400) green-screen sessions, batch jobs, MSGW handling, and spool file processing.
Scaling the Lakehouse: Unifying Databricks on AWS with HCL Universal Orchestrator
  |  May 21, 2026
Automate Databricks on AWS workflows with HCL Universal Orchestrator for scalable analytics, ML pipelines, ETL, and lakehouse operations.
