Validating a system’s APIs across a range of network protocols and message formats is a must these days.
Test cases have to be created to examine individual exchanges within larger transactions. And, this should be done in a non-intrusive manner using the same technologies for recording and service virtualization.
HCL OneTest API triggers and validates a system’s APIs across a range of network protocols and message formats.
HCL OneTest API provides a scripting-free environment for developing tests for enterprise messaging and business process integration projects. HCL OneTest API’s authoring environment provides the ability to use the same tools for environment discovery, system modelling and message recording to provide baseline data for creating tests.
Sample messages can be created and referenced in multiple test cases for maximum reusability. These messages can be used as templates, enabling simple updates for a group of tests, and shared validation rules allow re-use of validations across multiple test cases.
Learn more about HCL OneTest API or schedule a demo.
  |  September 11, 2019
Accelerating your test automation with the power of containers
HCL OneTest provides software testing tools to support a DevOps approach: API testing, functional testing, UI testing, performance testing and service virtualization.
  |  March 31, 2021
Advancing Avionics Verification and Validation
Avionics software engineering projects are challenging due to the risk of failure in the software – where an error could result in fatal loss. Read more.
  |  October 21, 2019
Developing the Data You Need for On-Demand Testing
With General Data Protection Regulation (GDPR) and other privacy regulations in effect, replicating existing data from production systems and using it in test environments has become much riskier (especially where personal data is concerned).
