Are you familiar with Automation Hub! It is the time.
Data! We have enough data to process.
Analyze! We have multiple software and algorithms to analyze and process the data.
Question is how to represent or publish the processed data together as a report. There are few which do this favor.
But, will the generated reports be flexible for reuse? Will the report maintenance be easy? Will they have an optimized data extraction and data generation process?
Answering is tough. Because it is not easy to maintain and produce efficient reports from huge data consistently with an ease.
Big fishes like Oracle, IBM will have the trick to satisfy the customer with the required features.
There comes our plugin OBI Run Report to answer all the queries with minimal effort which is associated with Oracle BI publisher.
This can be combined with the workload automation tool by the users.
Yes, reports are generated and published with the requirements. How to reach them to the customers.
Simple answer is by using agents. Agents can deliver the reports to the customers based on the trigger events and the targets. Targets can be different, in other way, the delivery routes can be varying by multiple conditions and requirements.
Agents are triggered by schedules or conditions that in turn generates a request to perform analytics on data based upon defined criteria, which can be used for reports scheduling as well as alerts sent to the required recipients on different web accessible / communication devices.
Agents also provide proactive delivery of real-time, personalized, and actionable intelligence throughout the business network.
As a next block of feature, we introduce OBI agent which help to satisfy the requirement. This plugin shares the features with Oracle iBot/agent in all aspects and they are part of session-based web services and associated with workload automation.
Technical description and workflow
OBI Run Report plugin
Defined from the business use case that Oracle BI publisher provide pixel-perfect published reporting solution for enterprise reporting needs and customers can create BI Publisher reports using host of features provided in the Report Designer to suit their requirements.
With OBI Run Report plugin they can run a specific report in the BI Publisher Server and save the generated report to defined location.
Prerequisite for the plugins to work:
OBIEE 12C or above installation
BI Publisher reports can be generated in 2 ways by this plugin.
  – On OBI server
  – On Agent Workstation
For both the cases must provide the path for report generation.
Log in to the Dynamic Workload Console and open the Workload Designer. Choose to create a new job and select “Oracle Business Intelligence Run Report” job type in the ERP section:
oracle business intelligence run report
Establishing connection to the OBI server:
In the connection tab provide hostname, port and credential of the server.
obi server connection
A connection message is displayed when the connection is established.
test connection
Required Run Report Absolute path and format
obi action
Submitting the job stream:
obi action
Track/ monitor the submitted job:
You can easily monitor the submitted job in WA through navigating to “Monitor Workload” page. 
monitor workload
Logs for the OBI server report creation:
job log details
Generated report can be saved as different formats. The report looks like this:
demo report
Report generation for OBI agent workstation:
run report information
Submit the job stream with absolute path and format:
report generation
Track/Monitor the job via “Monitor workload” page:
monitor jobs
Log for the OBI agent workstation:
clear filter
OBI agent plugin
iBot or agent (OBIEE)
software-based intelligent agents utility used for reports scheduling as well as Alerts sent to the required recipients on different web accessible/communication devices. Used to access, filter, perform analysis on data and that execute requests and generate responses to the appropriate people and devices.
Elements contains: –
  – Priority and visibility
  – Conditional request
  – Schedule
  – Recipients
  – Delivery content
  – Destination
The agent can be event-based or scheduled and provide constant monitoring and intelligence spanning operational and business intelligence sources.
Architecture: –
OBIEE (Oracle Business Intelligence Enterprise Edition)
Business Intelligence (BI) is tool by Oracle Corporation which has a prove architecture and common infrastructure producing and delivering enterprise reports, scorecards, dashboards, ad-hoc analysis, predictive alerts, notifications and OLAP analysis provides a rich end-user experience.
oracle bi domain
Components of OBIEE.
– Oracle Business Intelligence 12c (12.2.1.4.0)
– Oracle Database 12c
– Oracle Fusion middleware12c (12.2.1.4.0)
– Credentials and roles for user to establish a connection with OBI Server and run OBI Agent.
 For more details, use the official Oracle Documentation
https://docs.oracle.com/middleware/bi12214/biee/index.html
https://docs.oracle.com/cd/E17904_01/bi.1111/e10541/deliversconfigset.htm#BIESG1360
obi agent
server connection info
obi test connection
path of the agent created by user in OBIEE
agent information
You can also easily monitor the submitted job in WA through navigating to “Monitor Workload” page. 
obi monitor jobs
Logs for the agent creation
obi job logs
Agent properties
obiagent properties
Alert window for the agents.
oracle alerts
workload automation
Data is endless. Best way to oversee them is finding a friend who handle it with ease and wise.
Workload automation can help you for what you are looking at.
Drop a mail at santhoshkumar.kumar@hcl.com for details on the plugins.
Authors Bio
gaurav kulkarniGaurav Kulkarni, Technical Specialist at HCLSoftware
Experience in Java technologies like Hibernate, Spring boot, Web Services and REST APIs, UI technologies like native JavaScript, jQuery, ReactJS, python flask, Databases like Postgres, Oracle. Enthusiast about full stack software development and other similar technologies.
www.linkedin.com/in/gaurav-kulkarni-62742b27
akhilesh chandraAkhilesh Chandra, Developer at HCLSoftware
Java Developer, Experience in Cross Domain, Working Experience in Spring framework, Spring Boot, web services, Core java, J2EE and Database. Interested in artificial intelligence, python, machine learning and data science.
https://www.linkedin.com/in/akhilesh-chandra-442268a8
rooparani karutiRooparani Karuti – Senior Test Specialist at HCLSoftware
Working as senior test specialist for wo Workload Automation team in HCLSoftware, Bangalore. Worked both in manual and automation test scenarios across various domains.
https://www.linkedin.com/in/roopa-karuti-080b7627/
Comment wrap
Automation | May 20, 2024
HCL Workload Automation 10.2.2: Enhanced Security, Flexibility, and Efficiency
HCL Workload Automation 10.2.2 streamlines your processes with simplified installation, enhanced security via rootless installs and CyberArk integration, plus observability with OpenTelemetry.
Automation | February 6, 2024
Send Email Plug-in: Deliver Emails Simply and Effectively
Automate email delivery with Send email plug-in for Workload Automation. Simplify communication workflows, improve efficiency, and download now!
Automation | August 23, 2023
The New Kubernetes Plugin in HCL Workload Automation
Read how to automate container orchestration with the new Kubernetes plugin in HCL Workload Automation.
