This blog aims to show how SAP Calendar Import could be done through Workload Automation. Workload Automation as a product has ready made integration with SAP since the 90’s leveraging the SAP RFC Libraries of SAP using the SAP R/3 Batch Access Method.
Now , we would see how we can use this same access method to import Freeday Calendars or Workday Calendars from an SAP R/3 System into Workload Automation.
The r3batch access method can be invoked from TWS/methods Directory(in the older versions) or from the TWSDATA/methods directory in the Newer versions . The export can be for both Freeday Calendars as well as Workday Calendars. The below example is an export of a Freeday Calendar referenced by the Factory Calendar ID 02 exported into a text file /tmp/calendar_03.dat with the name HLI :
wauser@wa-server:/opt/wa/TWS/methods$ ./r3batch -t RSC -c S4HANAR3BW — ” –calendar_id 02 –year_from 2020 –year_to 2021 –tws_name HLI –getfreedays -filename ‘/tmp/calendar_03.dat’ “
Tue Mar 10 09:48:58 2020
-t RSC represents that the import is for an RFC SAP Calendar.
-c CalendarName represents that the Calendar name which is imported from the specific SAP System.
–calendar_id XX denotes a 2 Character identifier of the SAP R/3 Calendar to be imported.
–year_from XXXX denotes the Start year from which to start exporting the dates.
–year_to XXXX denotes the End Year upto which you can export dates.
–getfreedays indicates that the export is for Freedays.
-filename ‘<PATH>/CalendarFileName’ indicates the name of the file to which export is to be done on the Host OS where you are issuing the command.
The exported Calendar can be viewed in the File as shown below :
wauser@wa-server:/opt/wa/TWS/methods$ cat /tmp/calendar_03.dat
$CALENDAR
HLI
  01/01/2020 01/04/2020 01/05/2020 01/11/2020 01/12/2020 01/18/2020 01/19/2020
  01/25/2020 01/26/2020 02/01/2020 02/02/2020 02/08/2020 02/09/2020 02/15/2020
  02/16/2020 02/22/2020 02/23/2020 02/29/2020 03/01/2020 03/07/2020 03/08/2020
  03/14/2020 03/15/2020 03/21/2020 03/22/2020 03/28/2020 03/29/2020 04/04/2020
  04/05/2020 04/10/2020 04/11/2020 04/12/2020 04/13/2020 04/18/2020 04/19/2020
  04/25/2020 04/26/2020 05/01/2020 05/02/2020 05/03/2020 05/09/2020 05/10/2020
  05/16/2020 05/17/2020 05/21/2020 05/23/2020 05/24/2020 05/30/2020 05/31/2020
  06/01/2020 06/06/2020 06/07/2020 06/13/2020 06/14/2020 06/20/2020 06/21/2020
  06/27/2020 06/28/2020 07/04/2020 07/05/2020 07/11/2020 07/12/2020 07/18/2020
  07/19/2020 07/25/2020 07/26/2020 08/01/2020 08/02/2020 08/08/2020 08/09/2020
  08/15/2020 08/16/2020 08/22/2020 08/23/2020 08/29/2020 08/30/2020 09/05/2020
  09/06/2020 09/12/2020 09/13/2020 09/19/2020 09/20/2020 09/26/2020 09/27/2020
  10/03/2020 10/04/2020 10/10/2020 10/11/2020 10/17/2020 10/18/2020 10/24/2020
  10/25/2020 10/31/2020 11/01/2020 11/07/2020 11/08/2020 11/14/2020 11/15/2020
  11/21/2020 11/22/2020 11/28/2020 11/29/2020 12/05/2020 12/06/2020 12/12/2020
  12/13/2020 12/19/2020 12/20/2020 12/24/2020 12/25/2020 12/26/2020 12/27/2020
  12/31/2020 01/01/2021 01/02/2021 01/03/2021 01/09/2021 01/10/2021 01/16/2021
  01/17/2021 01/23/2021 01/24/2021 01/30/2021 01/31/2021 02/06/2021 02/07/2021
  02/13/2021 02/14/2021 02/20/2021 02/21/2021 02/27/2021 02/28/2021 03/06/2021
  03/07/2021 03/13/2021 03/14/2021 03/20/2021 03/21/2021 03/27/2021 03/28/2021
  04/02/2021 04/03/2021 04/04/2021 04/05/2021 04/10/2021 04/11/2021 04/17/2021
  04/18/2021 04/24/2021 04/25/2021 05/01/2021 05/02/2021 05/08/2021 05/09/2021
  05/13/2021 05/15/2021 05/16/2021 05/22/2021 05/23/2021 05/24/2021 05/29/2021
  05/30/2021 06/05/2021 06/06/2021 06/12/2021 06/13/2021 06/19/2021 06/20/2021
  06/26/2021 06/27/2021 07/03/2021 07/04/2021 07/10/2021 07/11/2021 07/17/2021
  07/18/2021 07/24/2021 07/25/2021 07/31/2021 08/01/2021 08/07/2021 08/08/2021
  08/14/2021 08/15/2021 08/21/2021 08/22/2021 08/28/2021 08/29/2021 09/04/2021
  09/05/2021 09/11/2021 09/12/2021 09/18/2021 09/19/2021 09/25/2021 09/26/2021
  10/02/2021 10/03/2021 10/09/2021 10/10/2021 10/16/2021 10/17/2021 10/23/2021
  10/24/2021 10/30/2021 10/31/2021 11/06/2021 11/07/2021 11/13/2021 11/14/2021
  11/20/2021 11/21/2021 11/27/2021 11/28/2021 12/04/2021 12/05/2021 12/11/2021
  12/12/2021 12/18/2021 12/19/2021 12/24/2021 12/25/2021 12/26/2021 12/31/2021
The exported Calendar in the text file can be imported into Workload Automation using a composer add as shown below :
HCL Workload Automation(UNIX)/COMPOSER 9.5.0.01 (20190703)
Licensed Materials – Property of IBM* and HCL**
5698-WSH
(C) Copyright IBM Corp. 1998, 2016 All rights reserved.
(C) Copyright HCL Technologies Ltd. 2016, 2019 All rights reserved.
* Trademark of International Business Machines
** Trademark of HCL Technologies Limited
Installed for user “wauser“.
Locale LANG set to the following: “en“
User: wauser, Host:127.0.0.1, Port:31116
User: wauser, Host:localhost, Port:31114
-add /tmp/calendar_03.dat
AWSJCL003I The command “add” completed successfully on object “cal=HLI”.
AWSBIA302I No errors in /tmp/calendar_03.dat.
AWSBIA288I Total objects updated: 1
So , with the above Steps a Factory Freeday Calendar with ID 02 was imported Successfully into Workload Automation under the name HLI .
The below example is an export of a Factory Workday Calendar referenced by the Workday Calendar ID 02 exported into a text file /tmp/calendar_02.dat with the name NEW :
wauser@wa-server:/opt/wa/TWS/methods$ ./r3batch -t RSC -c S4HANAR3BW — ” –calendar_id 02 –year_from 2020 –year_to 2021 –tws_name NEW –tws_description ‘SAP Calendar 02’ –getworkdays -filename ‘/tmp/calendar_02.dat’ “
Tue Mar 10 09:43:43 2020
The exported Calendar can be displayed and viewed as follows :
wauser@wa-server:/opt/wa/TWS/methods$ cat /tmp/calendar_02.dat
$CALENDAR
NEW
  “SAP Calendar 02”
  01/02/2020 01/03/2020 01/06/2020 01/07/2020 01/08/2020 01/09/2020 01/10/2020
  01/13/2020 01/14/2020 01/15/2020 01/16/2020 01/17/2020 01/20/2020 01/21/2020
  01/22/2020 01/23/2020 01/24/2020 01/27/2020 01/28/2020 01/29/2020 01/30/2020
  01/31/2020 02/03/2020 02/04/2020 02/05/2020 02/06/2020 02/07/2020 02/10/2020
  02/11/2020 02/12/2020 02/13/2020 02/14/2020 02/17/2020 02/18/2020 02/19/2020
  02/20/2020 02/21/2020 02/24/2020 02/25/2020 02/26/2020 02/27/2020 02/28/2020
  03/02/2020 03/03/2020 03/04/2020 03/05/2020 03/06/2020 03/09/2020 03/10/2020
  03/11/2020 03/12/2020 03/13/2020 03/16/2020 03/17/2020 03/18/2020 03/19/2020
  03/20/2020 03/23/2020 03/24/2020 03/25/2020 03/26/2020 03/27/2020 03/30/2020
  03/31/2020 04/01/2020 04/02/2020 04/03/2020 04/06/2020 04/07/2020 04/08/2020
  04/09/2020 04/14/2020 04/15/2020 04/16/2020 04/17/2020 04/20/2020 04/21/2020
  04/22/2020 04/23/2020 04/24/2020 04/27/2020 04/28/2020 04/29/2020 04/30/2020
  05/04/2020 05/05/2020 05/06/2020 05/07/2020 05/08/2020 05/11/2020 05/12/2020
  05/13/2020 05/14/2020 05/15/2020 05/18/2020 05/19/2020 05/20/2020 05/22/2020
  05/25/2020 05/26/2020 05/27/2020 05/28/2020 05/29/2020 06/02/2020 06/03/2020
  06/04/2020 06/05/2020 06/08/2020 06/09/2020 06/10/2020 06/11/2020 06/12/2020
  06/15/2020 06/16/2020 06/17/2020 06/18/2020 06/19/2020 06/22/2020 06/23/2020
  06/24/2020 06/25/2020 06/26/2020 06/29/2020 06/30/2020 07/01/2020 07/02/2020
  07/03/2020 07/06/2020 07/07/2020 07/08/2020 07/09/2020 07/10/2020 07/13/2020
  07/14/2020 07/15/2020 07/16/2020 07/17/2020 07/20/2020 07/21/2020 07/22/2020
  07/23/2020 07/24/2020 07/27/2020 07/28/2020 07/29/2020 07/30/2020 07/31/2020
  08/03/2020 08/04/2020 08/05/2020 08/06/2020 08/07/2020 08/10/2020 08/11/2020
  08/12/2020 08/13/2020 08/14/2020 08/17/2020 08/18/2020 08/19/2020 08/20/2020
  08/21/2020 08/24/2020 08/25/2020 08/26/2020 08/27/2020 08/28/2020 08/31/2020
  09/01/2020 09/02/2020 09/03/2020 09/04/2020 09/07/2020 09/08/2020 09/09/2020
  09/10/2020 09/11/2020 09/14/2020 09/15/2020 09/16/2020 09/17/2020 09/18/2020
  09/21/2020 09/22/2020 09/23/2020 09/24/2020 09/25/2020 09/28/2020 09/29/2020
  09/30/2020 10/01/2020 10/02/2020 10/05/2020 10/06/2020 10/07/2020 10/08/2020
  10/09/2020 10/12/2020 10/13/2020 10/14/2020 10/15/2020 10/16/2020 10/19/2020
  10/20/2020 10/21/2020 10/22/2020 10/23/2020 10/26/2020 10/27/2020 10/28/2020
  10/29/2020 10/30/2020 11/02/2020 11/03/2020 11/04/2020 11/05/2020 11/06/2020
  11/09/2020 11/10/2020 11/11/2020 11/12/2020 11/13/2020 11/16/2020 11/17/2020
  11/18/2020 11/19/2020 11/20/2020 11/23/2020 11/24/2020 11/25/2020 11/26/2020
  11/27/2020 11/30/2020 12/01/2020 12/02/2020 12/03/2020 12/04/2020 12/07/2020
  12/08/2020 12/09/2020 12/10/2020 12/11/2020 12/14/2020 12/15/2020 12/16/2020
  12/17/2020 12/18/2020 12/21/2020 12/22/2020 12/23/2020 12/28/2020 12/29/2020
  12/30/2020 01/04/2021 01/05/2021 01/06/2021 01/07/2021 01/08/2021 01/11/2021
  01/12/2021 01/13/2021 01/14/2021 01/15/2021 01/18/2021 01/19/2021 01/20/2021
  01/21/2021 01/22/2021 01/25/2021 01/26/2021 01/27/2021 01/28/2021 01/29/2021
  02/01/2021 02/02/2021 02/03/2021 02/04/2021 02/05/2021 02/08/2021 02/09/2021
  02/10/2021 02/11/2021 02/12/2021 02/15/2021 02/16/2021 02/17/2021 02/18/2021
  02/19/2021 02/22/2021 02/23/2021 02/24/2021 02/25/2021 02/26/2021 03/01/2021
  03/02/2021 03/03/2021 03/04/2021 03/05/2021 03/08/2021 03/09/2021 03/10/2021
  03/11/2021 03/12/2021 03/15/2021 03/16/2021 03/17/2021 03/18/2021 03/19/2021
  03/22/2021 03/23/2021 03/24/2021 03/25/2021 03/26/2021 03/29/2021 03/30/2021
  03/31/2021 04/01/2021 04/06/2021 04/07/2021 04/08/2021 04/09/2021 04/12/2021
  04/13/2021 04/14/2021 04/15/2021 04/16/2021 04/19/2021 04/20/2021 04/21/2021
  04/22/2021 04/23/2021 04/26/2021 04/27/2021 04/28/2021 04/29/2021 04/30/2021
  05/03/2021 05/04/2021 05/05/2021 05/06/2021 05/07/2021 05/10/2021 05/11/2021
  05/12/2021 05/14/2021 05/17/2021 05/18/2021 05/19/2021 05/20/2021 05/21/2021
  05/25/2021 05/26/2021 05/27/2021 05/28/2021 05/31/2021 06/01/2021 06/02/2021
  06/03/2021 06/04/2021 06/07/2021 06/08/2021 06/09/2021 06/10/2021 06/11/2021
  06/14/2021 06/15/2021 06/16/2021 06/17/2021 06/18/2021 06/21/2021 06/22/2021
  06/23/2021 06/24/2021 06/25/2021 06/28/2021 06/29/2021 06/30/2021 07/01/2021
  07/02/2021 07/05/2021 07/06/2021 07/07/2021 07/08/2021 07/09/2021 07/12/2021
  07/13/2021 07/14/2021 07/15/2021 07/16/2021 07/19/2021 07/20/2021 07/21/2021
  07/22/2021 07/23/2021 07/26/2021 07/27/2021 07/28/2021 07/29/2021 07/30/2021
  08/02/2021 08/03/2021 08/04/2021 08/05/2021 08/06/2021 08/09/2021 08/10/2021
  08/11/2021 08/12/2021 08/13/2021 08/16/2021 08/17/2021 08/18/2021 08/19/2021
  08/20/2021 08/23/2021 08/24/2021 08/25/2021 08/26/2021 08/27/2021 08/30/2021
  08/31/2021 09/01/2021 09/02/2021 09/03/2021 09/06/2021 09/07/2021 09/08/2021
  09/09/2021 09/10/2021 09/13/2021 09/14/2021 09/15/2021 09/16/2021 09/17/2021
  09/20/2021 09/21/2021 09/22/2021 09/23/2021 09/24/2021 09/27/2021 09/28/2021
  09/29/2021 09/30/2021 10/01/2021 10/04/2021 10/05/2021 10/06/2021 10/07/2021
  10/08/2021 10/11/2021 10/12/2021 10/13/2021 10/14/2021 10/15/2021 10/18/2021
  10/19/2021 10/20/2021 10/21/2021 10/22/2021 10/25/2021 10/26/2021 10/27/2021
  10/28/2021 10/29/2021 11/01/2021 11/02/2021 11/03/2021 11/04/2021 11/05/2021
  11/08/2021 11/09/2021 11/10/2021 11/11/2021 11/12/2021 11/15/2021 11/16/2021
  11/17/2021 11/18/2021 11/19/2021 11/22/2021 11/23/2021 11/24/2021 11/25/2021
  11/26/2021 11/29/2021 11/30/2021 12/01/2021 12/02/2021 12/03/2021 12/06/2021
  12/07/2021 12/08/2021 12/09/2021 12/10/2021 12/13/2021 12/14/2021 12/15/2021
  12/16/2021 12/17/2021 12/20/2021 12/21/2021 12/22/2021 12/23/2021 12/27/2021
The Calendar exported can be imported using a composer add command as follows:
5698-WSH
-add /tmp/calendar_02.dat
AWSJCL003I The command “add” completed successfully on object “cal=NEW“.
AWSBIA302I No errors in /tmp/calendar_02.dat.
So, with the above Steps a Factory Workday Calendar with ID 02 was imported Successfully into Workload Automation under the name NEW.
So, in this way, you can import any SAP Factory Calendar into Workload Automation easily or import all SAP Calendars needed for managing SAP Jobs, this greatly reduces any efforts needed in replicating SAP Calendars which are already defined on SAP Side to WA Side.
 Author’s Bio
sriram vSriram V
Sriram is working with Workload Automation for the last 11.5 years. Started out as a Scheduler, later as an Administrator, SME and India SME of the Product. He has been part of the Product Team in the last few years supporting Workload Automation on SaaS before moving to the Tech Sales and Lab Services of WA.
LinkedIn: https://www.linkedin.com/in/sriram-v-4163b820/
The Universal Adapter: Driving the Model Context Protocol (MCP) Client with Workload Automation
  |  September 7, 2026
Learn how HCL Workload Automation Model Context Protocol (MCP) Client acts as a universal adapter to connect MCP servers, tools, and enterprise workflows.
The Four Seasons of Enterprise Transformation
  |  May 22, 2026
Discover how enterprises unify workload automation, SaaS consolidation, governance, and AI agents into one strategic transformation cycle.
Unifying NoSQL and Automation: Automating MongoDB with Workload Automation
  |  May 21, 2026
Streamline MongoDB operations with Workload Automation for automated queries, database management, real-time workflows, and NoSQL orchestration.
