Don’t get left behind! The new era of digital transformation of businesses has moved on to new operating models such as containers and cloud orchestration.
Let’s find out how to get the best of Workload Automation (WA) by deploying the solution on a cloud-native environment such as Amazon Elastic Kubernetes Service (Amazon EKS).
This type of deployment makes the WA topology implementation 10x easier, 10x faster, and 10x more scalable compared to the same deployment in an on-premises classical platform. ​
In an Amazon EKS deployment, to best fit the cloud networking needs of your company, you can select the appropriate networking cloud components supported by the WA Helm chart to be used for the server and console components:
  • Load balancers
  • Ingresses
You can also leverage the Grafana monitoring tool to display WA performance data and metrics related to the server and console application servers (WebSphere Application Server Liberty Base). Grafana needs to be installed manually on Amazon EKS to have access to Grafana dashboards. Metrics provide drill-down for the state, health, and performance of your WA deployment and infrastructure.
In this blog you can discover how to:
  • Deploy WA components (Server, Agent, Console) in an Amazon EKS cluster, using one of the available cloud network configurations.
  • Download the Kubernetes job plug-in from the Automation Hub website and configure it in your AWS EKS cloud environment.
  • Monitor the WA solution from the WA customized Grafana Dashboard.
 Let’s start by taking a tour!!!
Deploy WA components (Server, Agent, Console) in an Amazon EKS cluster, using one of the available network configurations
In this example, we set up the following topology for the WA environment and we configure the use of the ingress network configuration for the server and console components:
  • 1 server
  • 2 dynamic agents
  • 1 console
Let’s demonstrate how you can roll out the deployment without worrying about the component installation process.
For more information about the complete procedure, see:
https://github.com/WorkloadAutomation/hcl-workload-automation-chart OR https://github.com/WorkloadAutomation/ibm-workload-automation-chart/blob/master/README.md
  1. Create hwa-test namespace for the Workload Automation environment
hwa-test
2. Add the Helm chart to the repo
Add the Workload Automation chart to your repo and then pull it on your machine
3. Customize the Helm Chart values.yaml file
Extract the package from the HCL or IBM Entitled Registry, as explained in the README file and open the values.yaml Helm chart file. The values.yaml file contains the configurable parameters for the WA components.
To deploy 2 Agents in the same instance, set the waagent replicaCount parameter to 2
replicaCount
Snap of replicaCount parameter from the values.yaml file
Set the Console exposeServiceType as Ingress as follows:
exposeServiceType
Snap of console Ingress configuration parameters from the values.yaml file
Set the server exposeServiceType as Ingress as follows:
exposeServiceType
Snap of server Ingress configuration parameters from the values.yaml file
Save the changes in the values.yaml file and get ready to deploy the WA solution
4. Deploy the WA environment configuration
Now it’s time to deploy the configuration. From the directory where the values.yaml file is located, run:
values.yaml
After about ten minutes, the WA environment is deployed and ready to use!
No other configurations or settings are needed, you can start to get the best of the WA solution in the AWS EKS cluster!
To work with the WA scheduling and monitoring functions, you can use the console as usual, or take advantage of the composer/conman command lines by accessing the WA master pod.
To figure out how to get the WA console URL, continue to read this article!
WA console URL
Workload Automation component pod view from the Kubernetes Manager tool Lens
Install and configure the Automation Hub Kubernetes plug-in
Let’s start to explore how to install and configure the native Kubernetes jobs on the AWS EKS environment.
NOTE: These installation steps are also valid for any other Plugin available in the Automation Hub catalog.
To download the Kubernetes Batch Job Plugin 9.5.0.02 version, go to the following Automation Hub URL:
Workload Automation Kubernetes Batch Job
Workload Automation Kubernetes Batch Job plugin in Automation Hub
  1. Download the package from Automation Hub and extract it to your machine Download the packageDownload the package from Automation Hub and extract it to your machine
2. Copy the JAR file in the DATA_DIR folder of your WA master pod
From the directory where you extracted the plug-in content, log in to your AWS EKS cluster, and run the command:
AWS EKS cluster
3. Copy the JAR file in the applicationJobPlugin folder
Access the master pod and copy the Kubernetes JAR file from the /home/wauser/wadata/wa-plugin folder to the applicationJobPlugin folder.
Copy command from the Server pod terminal
4. Restart the application server
From the appservertools folder in TWS inst directory run the commands
appservertools
Workload Automation application server start/stop commands.
Now the plugin is installed, and you can start creating Kubernetes job definitions from the Dynamic Workload Console.
5. Create and submit the job
To access the Dynamic Workload Console, you need the console ingress address. You can find it running the command:
Kubernetes command to get the list of ingress addresses.
Build up the URL of the console by copying the ingress address, as follows:
From the Workload Designer create a new Kubernetes job definition:
ingress address
Job definition search page from the Dynamic Workload Console.
Define the name of the job and workstation where the job runs:
Job definition page of the Dynamic Workload Console.
On the Connections page, check the connection to your cluster:
Dynamic Workload ConsoleConnection panel of the Kubernetes Batch Job plugin in the Dynamic Workload Console
From the Run Kubernetes Job page, specify the name of the Kubernetes job yaml file that you have defined on your workstation.
Kubernetes job configuration pageKubernetes job configuration page of Workload Automation console
Now there’s nothing left to do but save the job and submit it to run!!!
 As expected, the k8s job runs on a new pod deployed under the hwa-test namespace:
Kubernetes Batch job pod view
Kubernetes Batch job pod view from Kubernetes Manager tool Lens.
Once the job is done, the pod is automatically terminated.
Monitor the WA environment through the customized Grafana Dashboard
Now that your environment is running and you get how to install and use the plugins, you can monitor the health and performance of your WA environment.
Use the metrics that WA has reserved for you!!!
To get a list of all the amazing WA metrics  available, see the Metric Monitoring section of the readme: https://github.com/WorkloadAutomation/hcl-workload-automation-chart
 Log in to the WA custom Grafana Dashboard, and access one of the following available custom metrics:
list of workload automation
List of Workload Automation custom metrics from the Grafana dashboard
In each section, discover a brand-new way to monitor the health of your environment!
workload automation custom metrics
Workload Automation custom metrics from the Grafana dashboard – Pod resources
Take a look at the space available for your WA persistent volumes for WA DATA_DIR!
Workload Automation custom metrics from the Grafana dashboard Disk usage
full message queues
Full message queues are just an old memory!
Workload Automation custom metrics from the Grafana dashboard – Message queue
For an installation process example check this out!
Video image Video Play Button
Learn more about Workload Automation and get in touch with us here!
AUTHORS:
GirardiniSerena Girardini
She is the Verification Test manager for the Workload Automation product in distributed environments. She joined IBM in 2000 as a Tivoli Workload Scheduler developer and she was involved in the product relocation from the San Jose Lab to the Rome Lab during a short-term assignment in San Jose (CA).  For 14 years, Serena gained experience in Tivoli Workload Scheduler distributed product suite as a developer, customer support engineer, tester and information developer. She covered for a long time the role of L3 fix pack release Test Team Leader and, in this period, she was a facilitator during critical situations and upgrade scenarios at customer sitesIn her last 4 years at IBM, she became IBM Cloud Resiliency and Chaos Engineering Test Team Leader. She rejoined HCL in April, 2019 as an expert Tester and she was recognized as Test Leader for the product porting to the most important Cloud offerings in the market. She has a Bachelor Degree in Mathematics. Linkedin: https://www.linkedin.com/in/serenagirardini/
Louisa IentileLouisa Ientile
Louisa works as an Information Developer planning, designing, developing, and maintaining customer-facing technical documentation and multimedia assets.  Louisa completed her degree at University of Toronto, Canada, and currently lives in Rome, Italy.  Linkedin:  https://www.linkedin.com/in/louisa-ientile
Davide MalpassiniDavide Malpassini
He joined HCL in September 2019 as Technical Lead starting to work on IBM Workload Automation product suite. He has 14 years experience on software development and his activity was the extension of the Workload Automation product from a Kubernetes native environment to OpenShift Container Platform and  REST API for Engine of Workload Automation . He has a Computer Engineering Master Degree. Linkedin: https://www.linkedin.com/in/davide-malpassini-71b25582/
 Pasquale Peluso
He is a Workload Automation Software Engineer. He joined HCL in September 2019 in the Verification Test team. He works as verification tester for Workload Automation suite on distributed and cloud-native environments. He has a master’s degree in Automation Engineering. Linkedin: https://it.linkedin.com/in/pasqualepeluso
Filippo SorinoFilippo Sorino
He joined HCL in September 2019 as Junior Software Developer starting to work as Tester for IBM Workload Automation product suite.  He has a computer engineering bachelor’s degree. Linkedin: https://www.linkedin.com/in/filipposorino
Federico YusteenapparFederico Yusteenappar
He joined HCL in September 2019 as Junior Software Developer starting to work as Cloud Developer for IBM Workload Automation product suite. His main activity was the extension of the Workload Automation product from a Kubernetes native environment to OpenShift Container Platform. He has a Computer Engineering Master Degree. Linkedin: www.linkedin.com/in/federicoyusteenappar
The Universal Adapter: Driving the Model Context Protocol (MCP) Client with Workload Automation
  |  September 7, 2026
Learn how HCL Workload Automation Model Context Protocol (MCP) Client acts as a universal adapter to connect MCP servers, tools, and enterprise workflows.
The Four Seasons of Enterprise Transformation
  |  May 22, 2026
Discover how enterprises unify workload automation, SaaS consolidation, governance, and AI agents into one strategic transformation cycle.
Unifying NoSQL and Automation: Automating MongoDB with Workload Automation
  |  May 21, 2026
Streamline MongoDB operations with Workload Automation for automated queries, database management, real-time workflows, and NoSQL orchestration.
