Let us begin with understanding of Azure what it is all about before moving to our Azure Databricks plugin and how it benefits our workload automation users.
Azure
“Azure is an open and flexible cloud platform that enables you to quickly build, deploy and manage applications across a global network of Microsoft-managed datacentres. You can build applications using any language, tool, or framework. And you can integrate your public cloud applications with your existing IT environment.”
Azure is incredibly flexible, and allows you to use multiple languages, frameworks, and tools to create the customised applications that you need. As a platform, it also allows you to scale applications up with unlimited servers and storage.
What is an Azure Databricks?
Azure Databricks provides the latest versions of Apache Spark and allows you to seamlessly integrate with open-source libraries. Spin up clusters and build quickly in a fully managed Apache Spark environment with the global scale and availability of Azure.
Azure Databricks is a data analytics platform optimized for the Microsoft Azure cloud services platform. Azure Databricks offers three environments for developing data intensive applications: Databricks SQL, Databricks Data Science & Engineering, and Databricks Machine Learning.
  • Azure databricks plugin supports the latest analytic services for Azure data lake storage Gen1, Azure data lake storage Gen2, Azure blob storage, and other storage accounts.
  • It provides an easy-to-use platform for analysts to read data from multiple data sources and turn it into easily understandable data.
  • It provides faster performance with various optimizations at the I/O layer and processing layer (Databricks I/O).
Azure Databricks Plugin
Log in to the Dynamic Workload Console and open the Workload Designer. Choose to create a new job and select “Azure Databricks Plugin” job type in the Cloud section.
Fig1: Job DefinitionFig1: Job Definition
Connection Tab
Establishing connection to the Azure Databricks Workspace.
Workspace Instance – A unique instance name (per-workspace URL), that is assigned to each Azure Databricks deployment. It is the fully-qualified domain name used to log into your Azure Databricks deployment and make API requests.
Example: adb-<workspace-id>.<random-number>.azuredatabricks.net. The workspace ID appears immediately after adb- and before the “dot” (.). For the per-workspace URL https://adb-5555555555555555.19.azuredatabricks.net/
Access Token – Enter the access token that is generated in the Azure cloud, to authenticate to and access Databricks REST APIs.
We can generate token under User settings in workspace.
Fig 2Fig 2
Test Connection – Click to verify that the connection to the Azure server works correctly.
Connection TabFig 3: Connection Tab
Action Tab
Use this section to define the operation details.
Operation
  • Run the selected job
  • Cancel the pending/running job
Select – It gives the list of available jobs present in the workspace to select.
Details – It gives more information on selected job.
Action TabFig 4: Action Tab
Submitting your job
It is time to Submit your job into the current plan. You can add your job to the job stream that automates your business process flow. Select the action menu in the top-left corner of the job definition panel and click on Submit Job into Current Plan. A confirmation message is displayed, and you can switch to the Monitoring view to see what is going on.
Monitor page with extra propertiesFig 5: Monitor page with extra properties
Once we submit the job, we can cancel the particular job by Kill option.
Fig 6Fig 6
Job Log
Fig 7Fig 7
WA Logo
Are you curious to try out the Azure Storage plugin? Download the integrations from the Automation Hub and get started or drop a line at santhoshkumar.kumar@hcl.com
  |  July 24, 2023
Workload Automation: More than 100 Plugins Lets You Automate More (and Better)
The Automation Hub is an innovative work-in-progress as we regularly add many more items to it. It showcases HCL Workload Automation’s ability to orchestrate IT and business workloads.
  |  September 28, 2022
See your scheduling metrics on Prometheus and Grafana
HCL Workload Automation has exposed its metrics for the main components, the back-end which reports metrics around job execution.
  |  September 26, 2022
Easy Websphere's Liberty Management for the Workload Automation Administrator
Learn about how HWA main components are deployed on WebSphere liberty, that was designed to be highly efficient and optimized for modern cloud technologies.
