This blog describes how to set the custom location, if Custom HTML pages from locations other than the ZIEWeb publish directory are used.
STEPS :
  1. Create a new folder (like Customfolder).
  2. Launch the Deployment Wizard.
  3. Go to Advanced Options and select Code base.
  4. Specify the URL in the Code base field (Example: https://localhost/zie1).
Here, zie1 is the ZIEWeb publish directory Alias.
zie code base
5. Select the newly created Custom location in the Directory field.
custom location in the directory field
6. Create the HTML page.
7. Create the Alias for Custom folder in the webserver config page.
Here, the custom folder Alias is added to httpd.conf file using the Apache WebServer.
httpd conf file
8. Access the Custom HTML page in the browser.
custom html page
Here, customzie is the Custom folder Alias.
9. Launch the HTML page.
launch the html page
ZIEWIN and ZIEWEB Server Integration - Interoperability
  |  April 8, 2026
Learn how to integrate ZIEWin with ZIEWeb for centralized emulator profile management using Online Session Manager. Step-by-step configuration instructions included.
  |  November 24, 2021
Session Manager API In Z and I Emulator for Web Client
HCL ZIE for Web Client reads the existing session definitions from the Z and I Emulator for the Web server and allows users to connect to their System z and System I hosts.
